Publication date: 07/30/2020
Normal Mixtures Report
The Normal Mixtures report gives summary statistics for each cluster:
The Cluster Summary report gives the number of observations and proportion for each cluster.
The Cluster Means report gives means for the observations in each cluster for each variable.
The Cluster Standard Deviations report gives standard deviations for the observations in each cluster for each variable.
The -LogLikelihood table gives the negative log-likelihood, BIC, and AICc.
The Correlations for Normal Mixtures report gives the estimated correlation matrix for each cluster
