Basic Analysis > Oneway Analysis > Normal Quantile Plot
Publication date: 07/30/2020
You can create two types of normal quantile plots:
Plot Actual by Quantile creates a plot of the response values versus the normal quantile values. The quantiles are computed and plotted separately for each level of the X variable.
Plot Quantile by Actual creates a plot of the normal quantile values versus the response values. The quantiles are computed and plotted separately for each level of the X variable.
The Line of Fit option shows or hides the lines of fit on the quantile plots.
See Example of a Normal Quantile Plot.
