Publication date: 07/30/2020
Number Edit Box
Number Edit Box<<Set Format(<width>, <decimal places>, <"Use Thousands Separator">|<other options>)
Description
Sets the column format.
Arguments
A number of other formats can be set on number edit boxes. See Number Col Box<<Set Format(<width>|<width, decimal places>, <"Use Thousands Separator">) for more information about the syntax. Numeric Formats in Using JMP also describes the arguments.
