Scripting Guide > Types of Data > Numbers and Strings
Publication date: 07/30/2020
Numbers and Strings
Numbers can be written as integers, decimal numbers, in scientific notation with an E preceding the power of ten, and as date-time values. A single period by itself is the missing numeric value.
For example, these are all numbers:
.   1   12   1.234  3E3  0.314159265E+1 1E-20
One or more characters placed within double quotation marks constitute a string. For example, these are all strings:
"Green" "Hello,\NWorld!" "54"
Notice that if a number is in quotation marks, it is a string, not a number. There are two functions you can use to change a number into a string or a string into a number.
Use Num() to convert a string into a number. For example:
Num( "54" );
54
Note: Num() cannot convert non-numeric characters, so it produces a missing value.
Num( "Hello" );
Use Char() to convert a number into a string. For example:
Char( 54 );
"54"
Char( 3E3 )
"3000"
To preserve locale-specific numeric formatting in Num() or Char() output, include the <<Use Locale(1) option as shown in the following example:
Char( 42, 5, 2, << Use Locale( 1 ) );
// results in the character value "42,00" in the French locale
To look at each character in a string, use the Substr() function. This example looks for the letter “a” in the string and prints a message to the log:
ch = Substr( "alphabetic", 1, 1 ); // start and end with the first character
If( ch == "a",
	Print( "First letter is a." )
