Publication date: 07/30/2020
Options
You can also specify the following additional options:
New Column Name
Enables you to specify the name of the validation column.
Validation Column Type
(Not available for the Cutpoint Validation Column method.) Enables you to specify the validation column type as fixed or formula.
The fixed column type produces a column with fixed values.
The formula column type produces a formula column as the validation column.
Random Seed
(Not available for the Cutpoint Validation Column method or if a formula column type is specified.) Enables you to set a random seed to reproduce the same validation column in the future.
