Basic Analysis > Bivariate Analysis > Fit Orthogonal > Orthogonal Fit Ratio Report
Publication date: 07/30/2020
The Orthogonal Fit Ratio report shows summary statistics about the orthogonal regression model.
Variable
The names of the variables used to fit the line.
Mean
The mean of each variable.
Std Dev
The standard deviation of each variable.
Variance Ratio
The variance ratio used to fit the line.
Correlation
The correlation between the two variables.
Intercept
The intercept of the fitted line.
Slope
The slope of the fitted line.
LowerCL
The lower confidence limit for the slope.
UpperCL
The upper confidence limit for the slope.
Alpha
Enter the alpha level used in computing the confidence interval.
