Quality and Process Methods > Pareto Plots > Pareto Plot Platform Options
Publication date: 07/30/2020
The Pareto Plot red triangle menu contains options that customize the appearance of the plots. It also has options in the Causes submenu that affect individual bars within a Pareto plot. The following commands affect the appearance of the Pareto plot as a whole:
Percent Scale
Shows or hides the count and percent left vertical axis display.
N Legend
Shows or hides the total sample size in the plot area.
Category Legend
Shows or hides labeled bars and a separate category legend.
Pie Chart
Shows or hides the bar chart and pie chart representation.
Reorder Horizontal, Reorder Vertical
Reorders grouped Pareto plots when there is one or more grouping variables.
Ungroup Plots
Splits up a group of Pareto charts into separate plots.
Count Analysis
Performs defect per unit analyses. Enables you to compare defect rates and perform ratio tests across and within groups:
Per Unit Rates
Compares defect rates across groups. If a sample size is specified, Defects Per Unit (DPU) and Parts Per Million (PPM) columns are added to the report.
Test Rate Within Groups
Performs a likelihood ratio Chi-square test to determine whether the rates across causes are the same within a group. See Statistical Details for the Pareto Plot Platform.
Test Rates Across Groups
Performs a likelihood ratio Chi-square test to determine whether the rate for each cause is the same across groups. See Statistical Details for the Pareto Plot Platform.
Show Cum Percent Curve
Shows or hides the cumulative percent curve above the bars and the cumulative percent axis on the vertical right axis.
Show Cum Percent Axis
Shows or hides the cumulative percent axis on the vertical right axis.
Show Cum Percent Points
Shows or hides the points on the cumulative percent curve.
Label Cum Percent Points
Shows or hides the labels on the points on the cumulative curve.
Cum Percent Curve Color
Changes the color of the cumulative percent curve.
Causes
Has options that affect one or more individual chart bars. See Causes Options, for a description of these options.
See Local Data Filter, Redo Menus, and Save Script Menus in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
