Multivariate Methods > Partial Least Squares Models > Partial Least Squares Options
Publication date: 07/30/2020
The Partial Least Squares red triangle menu contains the following options:
Set Random Seed
Sets the seed for the randomization process used for KFold and Holdback validation. This is useful if you want to reproduce an analysis. Set the seed to a positive value, save the script, and the seed is automatically saved in the script. Running the script always produces the same cross validation analysis. This option does not appear when Validation Method is set to None, or when a validation column is used.
See Redo Menus and Save Script Menus in Using JMP for more information about the following options:
Redo
Save Script
Save By-Group Script
