Using JMP > JMP Reports > Add Images to a Graph or Report > Paste an Image at the End of a Report
Publication date: 07/30/2020
You can also add the graphic to the end of a report window. Copy the graphic from a graphics program onto your computer’s clipboard, display the report window, and select Edit > Paste.
