Using JMP > JMP Reports > Navigate Reports > Resize a Window
Publication date: 07/30/2020
Resize a Window
Report windows are automatically sized to fit the contents of the window. On Windows, you can automatically resize a window after manually resizing it. Hold down the Ctrl key and click the lower right corner of the window.
