JSL Syntax Reference > JSL Messages > Platforms > Response Screening
Publication date: 07/30/2020
Response Screening
obj<<Get PValues
Returns a reference to a PValues table.
obj<<Save PValues
Stores the p-values in an output data table.
obj<<Save Compare Means
Stores the means comparisons in an output data table.
obj<<Save Mean
Stores the means in an output data table.
obj<<Save Outlier Indicator
Saves Outlier Indicator for each fit.
obj<<Save Std Residuals
Saves the residual formula for each fit.
obj<<Select Columns
Select columns in the original table corresponding to selected rows in this table.
