Profilers > Custom Profiler > The Custom Profiler Report > Response Settings and Controls
Publication date: 07/30/2020
Figure 7.6 Response Settings and Controls
Response
The list of one or more responses.
Current Y
The predicted response based on the current X settings. This value updates as the factor settings are changed.
Lo Limit
Enables you to set a lower limit for your response.
High Limit
Enables you to set an upper limit for your response.
Benchmark
A saved predicted value of the response. Initially, this value is set to the predicted value when all factors are at their mean value.
Reset Benchmark
Updates the benchmark value to the current predicted value.
