Publication date: 07/30/2020
Right-Click Axis Options
Remove Graph
Removes the entire graph.
Remove
Removes a variable.
Note: If there is more than one chart type on the graph, a submenu listing the different charts is displayed. You can select which chart to remove.
For more information about the Axis Settings, Revert Axis, Add or Remove Axis Label, and Edit options, see Customize Axes and Axis Labels in the Axis Settings Window and Customize Axes and Axis Labels Using the Pop-Up Menu in Using JMP.
