Publication date: 07/30/2020
RSS Results Explorer Point Estimation Profilers
Each point estimation profiler within the Repairable Systems Simulation Results Explorer report has a red triangle menu that contains the following options:
Confidence Intervals
Shows or hides the 95% confidence intervals on the point estimation graphs.
Reset Factor Grid
Opens the Factor Settings window, which enables you to modify the parameters of the point estimation graph. See Reset Factor Grid in Profilers for more information about setting the factor grid.
Factor Settings
Provides additional options affecting the Factor Grid. See Factor Settings in Profilers for more information about Factor Settings.
