Discovering JMP > Save and Share Your Work > Save Platform Results in Journals
Publication date: 07/30/2020
Save platform reports for future viewing by creating a journal of the report window. The journal is a copy of the report window. You can edit or append additional reports to an existing journal. The journal is not connected to the data table. A journal is an easy way to save the results from several report windows in a single report window that you can share with others.
This section contains the following information:
Example of Creating a Journal
Add Analyses to a Journal
