Publication date: 07/30/2020
Save the Diagram as a Journal
Note the following about this approach:
This option can be a good choice for impromptu work. For example, you can manually build the diagram, save it as a journal, then reopen the journal later and continue building and editing the diagram.
Any customization exists only in the journal, and the journal is not connected to the data table.
To save the diagram as a journal:
1. Highlight the entire diagram.
2. Right-click and select Edit > Journal.
3. Save the new journal.
