Publication date: 07/30/2020
Save the Diagram as a Script
Note the following about this approach:
If you have other processes that need to update the data table, this can be a good approach to choose.
If you created the diagram from a data table, a simple script appears that relaunches against the data table with no customization.
If you created the diagram without using a data table (or from a journal), a more complex script appears that contains all the commands needed to add and customize each area of the diagram.
To save the diagram as a script:
1. Click the red triangle next to Cause and Effect Diagram and select Save Script > To Script Window.
2. Save the new script.
