Using JMP > Get Started > Manage JMP Files and Open Windows > Search for Recently Opened Files on Windows
Publication date: 07/30/2020
Recently opened files are listed in the Home Window. You can also search for recently opened files from any JMP window.
Select File > Quick Open or press Alt, Shift, and then O to open the Filter box and enter your search term. This option also lets you view the path of the file. Press Esc or click the X button to close the window after you type a search term.
