Using JMP > JMP Reports > Navigate Reports > Show and Hide Parts of a Report
Publication date: 07/30/2020
JMP reports are organized in a hierarchical outline. Each level of the outline has a triangle-shaped disclosure icon . Click the disclosure icon to open and close that section of the report.
You can also change which columns appear in a report. Right-click the report and select the column from the Columns list. To select more than one column at once, press Alt before right-clicking.
