Basic Analysis > Simulate > The Simulate Results Table > Simulation Results Report
Publication date: 07/30/2020
Original Estimate
The value of the original estimate, also shown in the first row of the Simulate Results data table. This estimate is labeled Y0.
Confidence Intervals
Lower and upper limits for quantile-based confidence intervals at the following significance levels: 0.05, 0.10, 0.20, and 0.50.
Empirical p-Values
The empirical p-values for a two-sided test and both one-sided tests that compare the simulated values to the original estimate. These p-values are computed as the proportions of the simulated values that fall in the ranges that are specified in the Test column of the report.
