Using JMP > Formula Editor > Customize Formulas > Specify the Matrix Size
Publication date: 07/30/2020
You can set the maximum width and height of matrices by selecting Max matrix size to show from the red triangle menu. If the width or height is greater than the specified size, the matrix dimensions show instead of the data. You can still see the data by editing the formula in the text editor window.
