Publication date: 07/30/2020
Standardize Attributes
By default, the items within the Standardize Attributes panel are dimmed. To access an item, click the Attributes button and select the items to be duplicated across columns.
Note: The Input Format item is applicable only for the Date, Time, and Duration formats.
To change the values of any of the attributes, use the menus in the Standardize Attributes panel.
