Predictive and Specialized Modeling > Modeling Utilities > Explore Patterns Utility > Statistical Details for the Explore Patterns Utility
Publication date: 07/30/2020
Rarity in Longest Runs
To calculate the rarity for longest runs, first define the following variables:
n = the number of rows in the column
k = the number of times a specific value occurs in the column
p = k/n = the probability of observing the specific value in the column
m = the length of the run
N = the number of unique runs
Then, the rarity for longest runs is calculated as follows:
Rarity = log2(1 (1 pm - 1)N)
Rarity in Longest Sequences
To calculate the rarity for longest sequences, first define the following variables:
p = the probability of observing the specific sequence one time in the column
k = the number of times the starting value of the sequence occurs in the column
Then, the rarity for longest sequences is calculated as follows:
Rarity = log2(1 (1 p)k)
