Discovering JMP > Introducing JMP > Understanding the JMP Workflow > Step 3: Requesting Additional Output
Publication date: 07/30/2020
Continue to use the same report window.
1. Click the red triangle next to Profits ($M) and select Test Mean.
The Test Mean window appears.
2. Enter 500 in the Specify Hypothesized Mean box.
3. Click OK.
The test for the mean is added to the report window.
Figure 2.8 Test for the MeanĀ
