Essential Graphing > Ternary Plots > Ternary Plot Platform Options
Publication date: 07/30/2020
The Ternary Plot red triangle menu contains options to modify the plot.
Note: To view more detailed options, right-click the plot.
Show Constraints
Shows or hides the constraints on the plot. The default plot shows the constraints.
Contour Fill
Allows filling of contours if a contour formula is specified in the plot. You can select Lines Only, Fill Above, or Fill Below. The default platform shows lines only.
Color Theme
Allows you to select a color theme. The default plot shows the Blue to Gray to Red color theme.
Show Points
Shows or hides the plotted points. The default plot shows the points.
See Local Data Filter, Redo Menus, and Save Script Menus in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
