Predictive and Specialized Modeling > Predictor Screening > The Predictor Screening Report
Publication date: 07/30/2020
The report (Figure 23.2) shows the list of predictors with their respective contributions and rank. Predictors with the highest contributions are likely to be important in predicting Y.
The Contribution column shows the contribution of each predictor to the bootstrap forest model. The Portion column in the report shows the percent contribution of each variable.
You can select the important predictors in the Predictor Screening report. Selecting the important predictors selects the corresponding columns in the data table, enabling you to easily enter these columns into the launch windows for modeling platforms. The Copy Selected button enables you to copy the selected columns to the clipboard so that you can paste them into a model as well. In this way, the Predictor Screening enhances the modeling process
