Essential Graphing > Legacy Platforms > Treemaps > Treemap Platform Options
Publication date: 07/30/2020
The Treemap red triangle menu provides the following options:
Change Color Column
Change the column that is currently used to color the rectangles.
Color Theme
Change the colors representing the high, middle, and low values of the color column. This option is available only if you have specified a Coloring variable.
Color Range
Specify the range that you want applied to the color gradient. The default low value is the column minimum, and the default high value is the column maximum. This option is available only if you have specified a continuous column as the Coloring variable.
Legend
Shows or hides a legend that defines the coloring used on the treemap. This option is available only if you have specified a Coloring variable.
Layout
Arranges rectangles by order of the variable or by size of the rectangle.
Split
Preserves the order of the data. Split is the default setting.
Squarify
Sorts the data first. The largest value is in the top left corner. The rectangle sizes decrease diagonally to the lower right corner. The order of the variables is not preserved, but visually comparing variables is easier.
Mixed
Preserves the order of the data for the main category and then sorts within the subcategory. Applies only when you select a category and subcategory.
See Local Data Filter, Redo Menus, and Save Script Menus in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
