Right-click a treemap to use the following options:
Suppress Box Frames
Suppresses the black lines outlining each box.
Ignore Group Hierarchy
Flattens the hierarchy and sorts by the Ordering columns without using grouping, except to define cells.
Show Labels
Shows or hides the Categories labels. If you have specified two Categories, the secondary labels are hidden or shown. If you hide the Categories labels, place your mouse pointer over a rectangle to show the primary or secondary category label.
Show Group Labels
Shows or hides the group labels. This option is available only if more than one variable is assigned to the Categories role.
Group Label Background
Adjust the transparency of the group label. This option is available only if more than one variable is assigned to the Categories role.
