Using JMP > JMP Reports > Use Markers
Publication date: 07/30/2020
Use Markers
Markers are points on a graph that represent data. Once they are changed from their default setting, they also appear next to rows in the data table.
Change Marker Shape
Change Marker Colors
Change Marker Size
Work with Crowded Markers
Add Outlines Around Markers
Marker Selection Modes
Specify Marker Transparency
Exclude and Hide Markers
Use Images as Markers
Change Marker Shape or Colors Based On Values
