Discovering JMP > Work with Your Data > Work with Data Tables
Publication date: 07/30/2020
This section contains the following information:
Edit Data
Select, Deselect, and Find Values
View or Change Column Information
Calculate Values with Formulas
Filter Data
Tip: Consider setting the Autosave Time Out value in the General preferences to automatically save open data tables at the specified number of minutes. This autosave value also applies to journals, scripts, projects, and reports.
