There are many ways that you can format your report to meet your needs. The sections that follow detail how to make changes to the graphical portions of your output reports.
Tip: If you have a touchscreen, you can pan and zoom most graphs and axes in JMP. Graphs and axes change scale and zoom out if pinched, and zoom in if stretched.
• Change the Background Color in a Graph
• Change the Color of Histogram Bars
• Display Coordinates and Temporary Reference Lines
• Customize Axes and Axis Labels in the Axis Settings Window
• Customize Axes and Axis Labels Using the Pop-Up Menu
