The red triangle menu of chart options appears when you click the icon next to the chart name. Some options are also available under Chart Options when you right-click the chart.
Needle
Connects plotted points to the center line with a vertical line segment.
Connect Points
Shows or hides the line that connects the data points.
Show Points
Shows or hides the points representing summary statistics.
Connect Color
Displays the JMP color palette for you to choose the color of the line segments used to connect points.
Center Line Color
Displays the JMP color palette for you to choose the color of the line segments used to draw the center line.
Limits Color
Displays the JMP color palette for you to choose the color of the line segments used in the upper and lower limits lines.
Line Width
Enables you to select the width of the control lines. Options are Thin, Medium, or Thick.
Point Marker
Enables you to select the marker used on the chart.
Show Center Line
Shows or hides the center line in the chart.
Show Control Limits
Shows or hides the chart control limits and their legends.
Limits Precision
Enables you to specify the decimal limit for labels.
Test Beyond Limits
Flags any point that is beyond the limits with a “*”. This test works on both UWMA and EWMA charts, regardless of the sample size being constant, and regardless of the size of k or the width of the limits.
