Publication date: 04/28/2021
Control Limits for XBar and R Charts
JMP generates control limits for XBar and R charts as:
LCL for XBar chart =
UCL for XBar chart =
LCL for R chart =
UCL for R chart =
Center line for R chart: By default, the center line for the ith subgroup (where 3 is the sigma multiplier) indicates an estimate of the expected value of Ri. This value is computed as: , where is an estimate of σ.
The standard deviation for XBar and R charts is estimated by:
where:
= weighted average of subgroup means
σ = process standard deviation
ni = sample size of ith subgroup
d2(n) is the expected value of the range of n independent normally distributed variables with unit standard deviation
d3(n) is the standard deviation of the range of n independent normally distributed variables with unit standard deviation
Ri is the range of ith subgroup
N is the number of subgroups for which ni ≥ 2.
