You can cut or copy any expression or an entire formula and paste it into another formula display. Use the cut, copy, and paste shortcut commands or right-click a highlighted part of the formula and select Cut, Copy, or Paste from the menu. The following aspects apply when you cut, copy, and paste a formula:
• When you paste it into another formula display, the formula appears in formatted form.
• The formula is saved on the clipboard as a JSL statement. Thus, if you copy it into other applications, it appears as a JMP Scripting Language (JSL) statement.
Note: Press the Shift key on your keyboard, and then click the red triangle to reveal a command called Copy As SAS Formula.
