N
Total number of observations.
DF
Records the degrees of freedom associated with the test. The degrees of freedom are equal to (c - 1)(r - 1), where c is the number of columns and r is the number of rows.
-LogLike
Negative log-likelihood, which measures fit and uncertainty (much like sums of squares in continuous response situations).
Rsquare (U)
Portion of the total uncertainty attributed to the model fit.
– An R2 of 1 means that the factors completely predict the categorical response.
– An R2 of 0 means that there is no gain from using the model instead of fixed background response rates.
See Tests Report.
Test
Lists two Chi-square statistical tests of the hypothesis that the response rates are the same in each sample category. See Tests Report.
Prob>ChiSq
Lists the probability of obtaining a Chi-square value greater than the one computed if no relationship exists between the response and factor. If both variables have only two levels, Fisher’s exact probabilities for the one-tailed tests and the two-tailed test also appear.
