Arg(expr, i)
Arg Expr(expr, i)
Description
Finds the argument numbered by i within the given expression.
Returns
The ith argument within the expression expr.
Empty() if that argument does not exist or is not specified.
Arguments
expr
an expression defined previously in the JSL script.
i
an integer denoting which argument to return.
Notes
Arg Expr() was deprecated in a previous release of JMP. Use Arg() instead.
Eval Expr(expr)
Description
Evaluates any expressions within expr, but leaves the outer expression unevaluated.
Returns
An expression with all the expressions inside expr evaluated.
Argument
expr
Any JSL expression.
Expr(x)
Description
Returns the argument unevaluated (expression-quoting).
Returns
The argument, unevaluated.
Argument
x
Any valid JSL expression.
Extract Expr(expr, pattern)
Description
Find expr matching pattern.
Returns
A pattern that matches the specified pattern.
Arguments
expr
Any expression.
pattern
Any pattern.
Head(exprArg)
Head Expr(exprArg)
Description
Returns the head of the evaluated expression, without its arguments.
Note
Head Expr() is deprecated. Use Head() instead.
Head Name(expr)
Head Name Expr(expr)
Description
Returns the head of the evaluated expression as a string.
Note
Head Name Expr() is deprecated. Use Head Name() instead.
N Arg(exprArg)
Description
Returns the number of arguments of the evaluated expression head.
N Arg Expr(exprArg)
Description
N Arg Expr() is deprecated. Use N Arg() instead.
Returns the number of arguments of the expression head.
Name Expr(x)
Description
Returns the unevaluated expression of x rather than the evaluation of x.
