Set Stage 1 p value
Set the p-value threshold used for Stage 1. See Stage 1 Methodology.
Set Stage 2 ratio
Specify the ratio of the Stage 2 MSE to the Stage 1 MSE. See Stage 2 Methodology.
See Local Data Filter, Redo Menus, and Save Script Menus in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
