The red triangle menu in the Fit Group Orthogonal Supersaturated Design platform contains the following options:
See Redo Menus and Save Script Menus in Using JMP for more information about the following options:
Redo
Save Script
Statistical Details for the Fit Group Orthogonal Supersaturated Platform
A two-stage strategy is used to fit group orthogonal supersaturated designs. The first stage identifies which groups contain active effects.
• Obtain an estimate of σ from the fake factors and then discard the fake factors from further analyses.
• Test for significance of each group of factors.
The second stage considers significance of individual factors in active groups. This stage uses a guided subsets procedure. See Jones and Nachtsheim (2016). For complete statistical details, see Jones, et al. (2019).
