Welcome to JMP > Learn about JMP > Formatting Conventions
Publication date: 04/28/2021
The following conventions help you relate written material to information that you see on your screen:
Sample data table names, column names, pathnames, filenames, file extensions, and folders appear in Helvetica (or sans-serif online) font.
Code appears in Lucida Sans Typewriter (or monospace online) font.
Code output appears in Lucida Sans Typewriter italic (or monospace italic online) font and is indented farther than the preceding code.
Helvetica bold formatting (or bold sans-serif online) indicates items that you select to complete a task:
buttons
check boxes
commands
list names that are selectable
menus
options
tab names
text boxes
The following items appear in italics:
words or phrases that are important or have definitions specific to JMP
book titles
variables
Features that are for JMP Pro only are noted with the JMP Pro icon . For an overview of JMP Pro features, visit https://www.jmp.com/software/pro.
Note: Special information and limitations appear within a Note.
Tip: Helpful information appears within a Tip.
