Scripting Guide > Extending JMP > JMP Live and JMP Public > Get an API Key (JMP Live Only)
Publication date: 04/28/2021
Before you can script reports and publish them to JMP Live, you must have an API key.
An API key is unique for a user and a JMP Live server. That means that if you change an existing API key, it overrides the previous one, and any scripts using the previous API key will need to be updated to use the new API key.
To obtain an API key:
1. Log into JMP Live.
2. At the top, click your profile name and select My Profile.
3. Click Edit.
4. Click Generate API Key. Make a note of your key.
