Note: You must have access to SAS, either on your local machine or on a server, to use SAS through JMP.
Using JMP, you can interact with SAS as follows:
• Write or create SAS code in JMP.
• Submit SAS code and view the results in JMP.
• Connect to a SAS Metadata Server or a SAS Server on a remote machine.
• Connect to SAS on your local machine.
• Open and browse SAS data sets.
• Retrieve and view data sets generated by SAS.
For more information about integrating JMP and SAS, see Import Data from SAS in Using JMP.
