The JMP Update preferences show you what version of JMP you currently have, the last time it was updated, and whether and how often JMP checks automatically for updates.
Figure 13.19 JMP Updates Preferences
Preference | Description |
Check for Updates | Select this option to have JMP automatically check for updates. If this option is selected, specify how often the check is performed: Daily, Weekly, or Monthly. |
Current Version | What version of JMP you are currently running. |
Last Check | The last time you checked for an update. |
Check Now | Click this button to perform an update check immediately. |
