The K Nearest Neighbors red triangle menu contains the following options:
Save Near Neighbor Rows
Saves K columns to the data table. The columns are named RowNear <k>. For a given row, the kth column contains the row number of its kth nearest neighbor.
Caution: The row numbers in the columns RowNear <k> do not update when you reorder the rows in your data table. If you reorder the rows, the values in those columns are incorrect.
Save Near Neighbor Distances
Saves K columns to the data table. The columns are named Distance <k>. For a given row, the kth column contains the distance to that row’s kth nearest neighbor.
See Local Data Filter, Redo Menus, and Save Script Menus in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
