Launch the Matched Pairs platform by selecting Analyze > Specialized Modeling > Matched Pairs.
Figure 19.3 The Matched Pairs Launch Window
Y, Paired Response
Provide the two response columns. For information about analyzing more than two responses, see Multiple Y Columns.
X, Grouping
Provide a grouping variable to compare the differences across groups. See Across Groups.
Weight
Identifies one column whose numeric values assign a weight to each row in the analysis.
Freq
Identifies one column whose numeric values assign a frequency to each row in the analysis.
By
Performs a separate matched pairs analysis for each level of the By variable.
After you click OK, the Matched Pairs report window appears. See The Matched Pairs Report.
