To launch the Simulate window, right-click a column of calculated values in a report window and select Simulate. Simulate is available in many reports, including all reports that support bootstrapping. To use Simulate, the data table must contain a formula with a random component that simulates data.
Note: The Simulate option is not available in reports that use a By variable.
