The commands on the Tables menu (and Tabulate on the Analyze menu) summarize and manipulate data tables into the format that you need for graphing and analyzing. This section describes five of these commands:
Summary
Creates a table that contains summary statistics that describe your data.
Tabulate
Provides a drag and drop workspace to create summary statistics.
Subset
Creates a table that contains a subset of your data.
Join
Joins the data from two data tables into one new data table.
Sort
Sorts your data by one or more columns.
For more information about these and the other Tables menu commands, see Reshape Data in Using JMP.
