The Means/Anova option performs an analysis of variance. If the X factor contains exactly two levels, this option appears as Means/Anova/Pooled t. In addition to the other reports, a Pooled t test report assuming pooled (or equal) variances appears.
Mean diamonds are added to the Oneway plot
See Display Options and Mean Diamonds and X-Axis Proportional.
Reports
See The Summary of Fit Report, The Analysis of Variance Report, The Means for Oneway Anova Report, The t Test Report, and The Block Means Report.
– The t test report appears only if the Means/Anova/Pooled t option is selected.
– The Block Means report appears only if you have specified a Block variable in the launch window.
