You can choose from the following types of mixture designs:
Optimal
Generates an optimal mixture design using the custom designer. See Optimal Mixture Design.
Simplex Centroid
Generates a design of pure mixtures and blends of factors up to a specified degree. In a pure mixture, one component is at 100% and all other components are at 0%. See Simplex Centroid Design.
Simplex Lattice
Generates a design of pure mixtures and blends in a space filling triangular grid of runs. You can specify the number of grid levels. See Simplex Lattice Design.
Extreme Vertices
Generates a design based on the vertices and combinations of the vertices of a constrained factor space. Available when you have linear constraints or restricted upper and lower bounds on one or more of your factors. See Extreme Vertices Design.
ABCD Design
Generates a screening design for mixtures devised by Snee (1975). See ABCD Design.
Space Filling
Generates a space filling design that accommodates linear constraints. See Space Filling Design.
Note: The optimal, extreme vertices, and space filling designs can incorporate linear constraints and restrictions on components.
