Fitting Linear Models > Standard Least Squares Examples > Response Surface Model Example
Publication date: 04/28/2021
This example fits a response surface model. Your objective is to minimize the response.
Fit the Full Response Surface Model
Reduce the Model
Examine the Response Surface Report
Find the Critical Point Using the Prediction Profiler
View the Surface Using the Contour Profiler
