Browse Data
Browse and import data residing on a SAS Server.
SAS Query Builder
Select and import data on a SAS server without writing SQL statements. See Build SQL Queries in Query Builder.
Export Data to SAS
Export JMP data tables to a SAS Server.
Browse SAS Folders
Browse and run SAS stored processes or open Metadata-defined data tables.
New SAS Program
Opens a script window for writing and submitting SAS code.
Submit to SAS
Sends SAS code directly from JMP to the currently active SAS server.
Open SAS Log Window
Opens a SAS log window for the active SAS server.
Open SAS Output Window
Opens a SAS output window for the active SAS server. This window shows recent SAS output.
Server Connections
Administer connections to SAS servers.
You can also find shortcuts for SAS options on the SAS page of the JMP Starter, and there is a SAS toolbar. You can save certain settings pertaining to SAS Integration on the SAS Integration page of the Preferences window (File > Preferences). For more information about setting your SAS Integration preferences, see SAS Integration in the JMP Preferences section.
